Venomous X Pressure Mount Confusion
mim3tic
Venomous X Pressure Mount AM3 = Disappointment
Ok I am a little bit peeved here in regards to the mounting options for the New Thermalright Ven-X I am running a Phenom II 965 which means that I have to purchase a separate retention/mounting kit for the Venomous X. See I can live with this, here is where I start to get Angry.
The only compatible kit they sell is the: Thermalright AM2 / AM2+ / AM3 Bolt-Thru Kit - Rev 2
My understanding was that one of the major improvements thermalright made for there Venomous X was it's pressure mounting system. Well the above AM3 kit is the same system Thermalright uses for there ULTRA-120 Trueblack REV.C 6 heatsink. So basically the AM3 mounting system isn't new or improved and lacks the 70 LBS pressure force that the new intel system has. So is it even worth it to but a Venomous X when I can get a TrueBlack for cheaper that also includes the AM3 mounting kit?
muddocktor
Retired
New Iberia, LA
I can't vouch for it on AM3 but I found that the Ven-X and the Rev. C TRUE to be about neck and neck for cooling capacity. The thing that made more difference was the Ven-X mount as compared to the 2 heatsinks. If I were you, I'd save the extra money and go with the TRUE Rev. C and if you want you could use the extra money for some good, quiet running fans or something.
BTW, I tested these head-to-head on the same platform, in the same case and with the same fans. I also tested the Megahalems and an original TRUE too. Unfortunately I ran out of time to do more remounts with the Megahalems and the original TRUE and post the results before I had to leave for the rig.
