- Jul 21, 2011
Hello all!
I hope you had a merry Christmas!
I've been postponing a build for a while now and am pretty sure I'm ready to pull the trigger on most of the components.
I'll be using an i5 6600k and an MSI 480 8gb.
I am trying to figure out which cooler to get and want to make sure it will fit in the case I want.
I am also concerned with the volume and coolness of the GPU depending on the case.
I'd also rather keep it on the low end of $
Coolers I'm looking at:
H60: http://www.newegg.com/Product/Product.aspx?Item=N82E16835181030&Tpk=35-181-030
H50: http://www.newegg.com/Product/Product.aspx?item=N82E16835181010
Enermax 240: http://www.newegg.com/Product/Produ...-cables-_-na-_-na&Item=N82E16835214061&cm_sp=
Cases I'm looking at:
CM Elite 130 (VERY tempting due to cost, but ITX and they RARELY have 2133 ram): http://www.newegg.com/Product/Produ...-cables-_-na-_-na&Item=N82E16811119286&cm_sp=
Thermaltake V21: http://www.newegg.com/Product/Produ...-cables-_-na-_-na&Item=N82E16811133274&cm_sp=
Corsair Carbide: http://www.newegg.com/Product/Produ...-cables-_-na-_-na&Item=N82E16811139044&cm_sp=
WWYD?
WWYD?
