- May 17, 2005
- High Desert, Calif.
My server board-to-desktop project is not quite complete, so
I'm in the market for a vertical Display Graphics Card bracket. and am looking for recommendations. The board on has 8X slots so I'm using a PCI Express 8X Male to PCI-E 16X Female
Riser Mining Cable for the present GPU. Hope to upgrade to a better on later(when prices fall) for GPU folding.
As you can see, I really need a better solution:
Here's where I'm envisioning the vertical bracket will have to be installed (guess I'll be breaking out the dremel):
Instead of cutting out the back of the case, perhaps I could use a GPU holder bracket like this one.
Would be an easier install, one of the product raters mentioned just snipping out the sheet-metal between the horizontal PCI slots.
I don't have any other add-on cards going into this case, so that would be acceptable.
