PROJECT LOG ❚❚ [Verticality by Duality92] ❚❚
Duality92
ver′ti·cal′i·ty
[vur-ti-kuh l]
adjective
1.
being in a position or direction perpendicular to the plane of the horizon; upright; plumb.
2.
of, relating to, or situated at the vertex.
3.
of or relating to the cranial vertex.
4.
Botany.
(of a leaf) having the blade in a perpendicular plane, so that neither of the surfaces can be called upper or lower.
being in the same direction as the axis; lengthwise.
5.
of, constituting, or resulting in vertical combination.
6.
of or relating to a product or service from initial planning to sale.
7.
of, relating to, or noting a stratified society, nation, etc.
noun
8.
something vertical, as a line or plane.
9.
a vertical or upright position.
10.
a vertical structural member in a truss."
Parts List
Hardware
AMD A10-7890K
Gigabyte GA-F2A88XN-WIFI
G.Skill Trident X 2*8GB 2400/10
G.Skill SSD
HDPlex 160W DC-ATX
HDPlex 160W AC-DC w/PFC​
Cooling
1 * Alphacool XT45 280
2 * Be Quiet! Silent Wings 3 PWM 140mm fans
1 * Alphacool DC-LT 2400 Ceramic Pump
1 * Alphacool DC-LT Pump Top | Plexi
4 * Alphacool Eiszapfen G1/4" 45° Angled Rotatable Adapter Fitting - Black
4 * Alphacool Eiszapfen G1/4" 90° Rotary L-Connector - Black
2 * Alphacool G1/4 16mm Knurled HardTube Compression Fitting - Black
1 * Alphacool G1/4 Bulkhead Connector - Black
1 * Alphacool G1/4 Round TEE Connection Terminal - Black
1 * Alphacool HardTube 16/13mm Plexi Clear 40cm
1 * Alphacool NexXxoS XP³ Light - Acetal - Intel/AMD
8 * 8mm / 11mm Compression Fittings
Modding
75 * Darkside 2mm (5/64") High Density Cable Sleeving - Graphite (DS-HD2-GMC)
25 * Darkside 2mm (5/64") High Density Cable Sleeving - Opaque Red (DS-0731)
2 * Darkside 7.75" (20cm) Dimmable Rigid RGB LED Strip (DS-0533)
1 * Darkside Custom Configurable Colour, Dual RGB LED Controller with Remote (DS-0535)
4 * MMM 18 AWG Ul1007 Hookup Wire 25' - Black (MOD-0147)
1 * MMM 24-Pin ATX Female Connector - Black (MOD-0096)
1 * MMM 24-Pin ATX Male Connector - Black (MOD-0095)
1 * MMM 4-Pin EPS Female Connector - Black (MOD-0105)
1 * MMM 4-Pin EPS Male Connector - Black (MOD-0104)
1 * MMM 5-Pin SATA Female Connector - Black (MOD-0106)
20 * MMM ATX Female Pin - 5 Pack (MOD-0116)
2 * MMM SATA Pin - 5 Pack (MOD-0117)
5 feet ModMyMods 8mm ID x 11mm OD PVC Tubing - Clear (58000)
1 * SIJIAWU Professional Wire Stripper and Cutter - 16 to 26 AWG (DY-011105)
1 * UPC Custom Pin Crimper (UPC-0001)​
3D Printed Parts
Motherboard, SSD and cable management bracket
Pump and Power Supply mounting bracket
Reservoir top and bottom
Base stand
Motherboard pin covers
Input cable management
Fan grills
Progress as of 2016-11-29
t1nm4n
Texas
Wonder if one of the cross flow AlphaCool rads might be better, can be like the fluid is just going in a circle, just a though. How much will the MB block airflow from the rad? Interesting none the less.
D
Duality92
It won't be blocking much airflow, I will be testing it once done, but if it ends up too restrictive, I can always just extend the brackets by a bit and reprint :)
D
Duality92
So I just got confirmation from AMD that I'll be getting an A10-7890K for the final piece of hardware :)
bob4933
Couple things I cant figure out.
Wheres the power supply going? Where are you mounting the SSD?
Very ambitious project, cant wait to see how it goes :D
D
Duality92
The power supply I will be using basically isn't out yet. It's basically like a PicoPSU, but made by HDPlex. It's a new revision of that one linked that isn't out yet.
The SSD will be mounted on the motherboard bracket, but on the opposite side between the radiator and bracket.
D
Duality92
The power supply won't be mounted on the motherboard though. The motherboard will even be modded :p
D
Duality92
Here are pictures of my custom case for the HDPlex 160W (new revision). Since it's a PicoPSU style power supply and I didn't want to mount it to the motherboard, this is my solution :)
I have completed the power supply case, the power supply bracket and the pump bracket. The main thing left to do is finalize the motherboard mount and make a few spacers for various locations to keep things even. Possibly 140mm fan grills too if I have long enough M3 screws.
[/CENTER]
D
Duality92
So the build isn't dead and I appologize for the lack of updates, I was faced with a big problem, the motherboard I had modded to remove the 24-pin and 4-pin connectors didn't survive the surgery I put it through. I had to order a new motherboard and design a custom PCB to achieve the look I was after
D
Duality92
Is all the tubing going to be hard tubing? This build is kind of made for it.
Very cool so far.
I can't stretch the budget that far! If you can convince modmymods to do so, maybe I will ;)
I'd just need the fittings and tubing.
D
Duality92
So here are the final pictures :)
Not 100% happy with how things turned out to be honest, so there will definetly be a Verticality II eventually!
