- Mar 3, 2005
- Central MA
I got my 2 Evga 980ti yesterday and I got around to getting them installed today and what a damn mess! These things are awful!! I was using two of my brother's 980s for the last month or so and they ran perfectly, nice and cool and quiet. Got pretty good FPS in BF4 and and never broke 80° under full load running 3 2560X1440 monitors. The cards are all stock. When using his cards, at idle without the fans running the temps were 37°~40° and playing BF4 they hit 71°~80°.
Now, I uninstalled all drivers, wiped them with driver cleaner, installed my cards and installed the latest drivers. Just enabling the 3 monitors I checked temps and everything looked good. 37° Idle temps with the fans running about 1150 RPM, so I go to the Nvidia control panel and enable surround, I immediately see the temps rise to 47°, then start creeping to 67°! And that's idle, just sitting there. Playing BF4 on ultra in surround was impossible because the cards would throttle, and I don't like to run them over 80°, so I set a fan profile and had to run them @4200 RPM to stay under 80° in the game and they are crazy loud! FPS were lower than my brother's cards, I was only getting 50~75 FPS on ultra. I was hitting 90 with the other cards, I had to set it to high in order to hit 90~100 FPS with the TIs? I also have to run the cards at 2300 RPM @ Idle to keep the temps in the 40s. Is anyone else running SLI 980TIs with hi res monitors out there that can chime in? I'm not expecting to run super quiet and cool on air but this is a little over the top. I think I'm going to have to throw some water blocks on them, but if the cards are running this hot on air Idle I'm a little worries about keeping them. And I'm not getting any performance gains over a 4GB 980?
Before anyone asks about air flow, the computer is clean and newly built. No air restrictions and good air flow. The specs are in my sig.
