very noisy =(
Gosu
i very bad in this moment , i buy new cpu cooler for my xp2000
and my board Epox 8k3a+
i very frustracion
my buy is ThermalRight AX-7 w/ Delta 80 Model FFB0812EHE, 80 CFM.
because ppl say this fan is the better in the world
but is to noisy , the noise it makes is like an airplane
im looking for another fan that operate at a low noise level but
with a good air volume but without noise
i need finish my pc this weekend
thanks my friends
Gilgamesh
Norman, OK
i very frustracion
thanks my friends
I think that fan is kicking 55dba you can add a rheostat to regulate the fans power or get a new fan either a sunon or ys-tech of 50cfm at http://www.svcompucycle.com/ they have fast and cheap shipping. I would buy a rheostat cheaper and better solution.
AntiHeiss
Senior Member
Texas
If you are looking for a quieter fan, and don't want to install a rheostat (which would be my opinion too). Then I would suggest buying a Panasonic Panaflo type fan. They move just as much air as the other fan types, but from my expierience they are much much quieter. Just a suggestion though. Good luck.
NeoMoses
If you can find a "squirrel cage" type blower, you can get good CFM ratings at lower decibels. And also, you don't have the hole in the center of airflow, like fans produce.
I got my blower out of an automotive heater, FYI. (try junkyards.)
