- Jan 9, 2005
- Livonia, MI
Very strange issue involving explorer.exe process. Windows experts: explain this.
My wife's computer is the second one in my sig: "Gray". It is running WinXP Pro and has developed a very strange problem sometime during the past few months. Here are the symptoms:
Certain simple operations, such as right-clicking on Windows desktop or copying/pasting a file using Windows Explorer, cause the mouse cursor to turn into an hourglass and remain in that state indefinitely. The system does not "freeze" or encounter a stop error. In fact, I am able to enter Task Manager via Ctrl-Alt-Del and kill the explorer.exe process. I can then restart the explorer.exe process and functionality is restored! Of course, the same thing will happen again if I repeat one of these simple operations.
The strange thing is that the computer functions perfectly fine when doing anything else. Productivity applications, IE, and games run without a hitch! My wife didn't even notice that anything was wrong with the comptuer because she never messes with any system settings or modify files outside of applications.
I have done many things, and even received assitance via a remote connection from a friend who is an IT professional. Here are some of the things that have been done:
- Ran HDD diagnostics: okay
- Checked disk for errors: none
- Cleaned unused/hidden devices from Device Manager
- Cleared the Windows temp folder
- Rebuilt icons using TweakUI
- Scanned for rootkits using F-Secure BlackLight: none
At this point I'm just thinking about restoring an older image of the OS partition. Do any of you have some ideas?
One thing I want to mention is that I *believe* these problems started after my wife tried to install some old game that only had support for Windows 98. After she did this, some very strange things happened, such as her Outlook data disappearing. I was able to restore it, but it was just a very odd situation. I suspect that this issue may be related to that failed installation.
