- Feb 5, 2001
- Baltimore
I just don't get it. I've tried installing the 4in1s and thought that I have but when I check the driver versions under system properties to match them up with the current driver set; system properties reads "no driver needed".
I've tried to install them seperately, downloaded them seperately, booted into safe mode and tried to update them manually, ran the 4in1 setup, and none of them have worked.
The IDE drivers do install but my HD scores are between that of an ATA33 and ATA66 (using HDtach, ATTO, and Sandra). Some suggested trying the Microsoft drivers but when I do that; windows doesn't recognize my drive and my scores are still kinda low. Via drivers do recognize the drive but my scores are low.
I'm using 98SE so it can't be the ATA100 bug that plagues those using 2000.
Any ideas? I'm just about to go and buy a promise card to see if that will solve the situation.
Amiel
Amiel
