safemode said:
Why do you care about the temps of your water when the computer is not running or when it's booting up. Those temps dont matter.
I disagree, starting off with water that is atleast 8c over ambient puts one at a disadvantage immediately. You know how water is good at cooling? That same property also makes it cool down from a higher temp slower. It resists cooling the same degree it resists being heated. There is now way that water starting at that temperature now being used to cool something hot can be as efficient as water starting off from room temperature.
First off your Tbird is overclocked from what? if you're operating at 1133 then it should be 1.7 volt, not 1.85.
Check the sig, it is overclocked with higher v for a REASON, stability. I am pushing the chip for all it is worth. When you reach a certain point of oc'ing a chip and it is unstable, what do you do? Increase voltage to get it stable. It worked, so I pushed it for all it is worth.
You shouldn't be concerned with the temp of your water when the computer is not running. It's a waste of time to care.
Again I disagree. Thermal properties (potential) of water negate that statement
.the Tbird is a chip that runs very hot.
I am glad you told me that, I had no idea!
Rather than buy fans which will add noise i'd just go and get the xp1700 tbred since it runs very cool and performs better than you can overclock your 1133 anyways. They cost what, 60 bucks.
Did you ever think for a moment I may have an XP 1600 on the way? Don't make assumptions.
I bet your temps are in line with what they should be though for the chips you're running at the ambient temp you're running at. The higher the ambient temp the more air you need to push over the radiator... So you've discovered that without a fan you need a delta temp of 8C for the heattransfer to equalize.
Here you are admitting you need to change the water temp 8C to get it to room temperature. What I am saying is there has to be a pump that does not put that kind of heat into the water to begin with. This pump is rated at 20W, the maxijet and eheim are 8.5 and 10W respectively. That has to equate to lower beginning temperatures of the water. I am running a fan over the radiator as I stated previously, though not when the computer is shut down.
I dont know what you're looking for here.
Then how can you answer? Why post? I am looking for suggestions from others in a manner different from yours. The previous replies have been in a helpful manner. From what I have read in many other threads that you have replied to, you are more argumentative than helpful. Just my two cents.
