Video Card Compatibility
Yuriman
The OCFORUMS
I dont think they have made a 32mb card since the Geforce2 era. Anyway, it all depends. If it has agp4x you are fine. If its a 2x board, you can use it.
Oni
Oni-ni-Kanab;, Ninja Hippo eater Moderator
St. Catharines, Ontario Canada
You mean size-wise? Yeah, it'll fit.
Will it work? Probably. From what I've read, the 8100 series has 4xAGP capabilities, so it should be just fine :)
wanna_b_rich_13
I also heard that ATI cards have many problems with DELLs b/c of driver issues and that is why you see a lot of them equipped with Geforces.
