- Dec 28, 2001
What i did was a found a square match box ruffly the shape and size of my vid card,then i cut to holes in it for 2 fans one 60mm delta and one 60mm somthing i'm not sure what.they are the same size though and the other is almost as strong.,then i used cable ties to hold them to the box then i sealed the box to the video card leaving just enough open to let the air out.i'm ganna test how it works.What do you guy's think is this a good idea or bad.
