Great choice, how much did it cost?just bought an EVGA 1080 ftw on Newegg... It seemed like the best choice.
It has one of the higher clock speeds, 3-year warranty, plus I love the company
oh, and it's pretty!
MSI and ASUS customers are still getting what they paid for. The difference is that instead of using the gaming profile, they are using the OC profile/BIOS. Its the best stock performance. I don't agree with it either, we should be reviewing a product as you get it in your hands...but, a lot of people made way more out of the issue than needed to be. EVERY SINGLE PERSON that buys those cards would reach those clocks by just using the OC profile (or flashing to the now available BIOSs). For the record, the difference between these profiles are so small that you barely get a 1% gain. Look at the 1070 I reviewed.. its 20 MHz on the core (of 1600 base)!!!!!Again, that's a very legit move, and it's the reason I'm loyal to EVGA. While other companies are advertising fake clock speeds, EVGA actually under-presents their clocks with lower guaranteed speeds than customers are actually receiving in many cases.
Why do they use gaming profile or overclock profile is it just a gimmick?MSI and ASUS customers are still getting what they paid for. The difference is that instead of using the gaming profile, they are using the OC profile/BIOS. Its the best stock performance. I don't agree with it either, we should be reviewing a product as you get it in your hands...but, a lot of people made way more out of the issue than needed to be. EVERY SINGLE PERSON that buys those cards would reach those clocks by just using the OC profile (or flashing to the now available BIOSs). For the record, the difference between these profiles are so small that you barely get a 1% gain. Look at the 1070 I reviewed.. its 20 MHz on the core (of 1600 base)!!!!!
Its not a gimmick, no. There are three modes... Silent, Gaming, and OC. IN the case of the 1070, there was a 20 MHz difference between Gaming mode and OC mode which yielded to ~1% difference across our tests. Now, the 1080 is different, it shows a clockspeed difference of 38 Mhz which will yield a bit more performance. So it varies. The difference between silent and OC Mode is likely a few percent.
The point of the app is for novices to get more out of their GPU.. one button/touch overclocking.
I could not find a Bios update for overclocking the Gigabyte GTX 1070 however I did find you have to use the software to reach the highest overclock.This did not affect Gigabyte cards. Only ASUS and MSI. At least, only ASUS and MSI shipped their cards with the higher/highest settings which is what caused 'all of this' and the OC BIOS to be available.
To answer the question directly, no... I doubt it (see why above). But you can check and report back.
1070 G1 GAMING has default clock frequencies of 1784 MHz (boost) / 1594 MHz (base) with a reference clocked 8192 MB GDDR5 / 8008 MHz effective data-rate on the memory. With the help of XTREME ENGINE software by pressing a button the card will go into OC mode and gets a 26 MHz overclock. That OC mode requires you to have the software active at all times, hence we will not use it. We test the graphics card at its default out of the box and thus BIOS settings. Let's head on-wards in the review. http://www.guru3d.com/articles-pages/gigabyte-geforce-gtx-1070-g1-gaming-review,1.html
