video fan
Hardass
Senior Member
I am running a nivida geforce2 gts the fan went can i run this card at default without a fan for a couple days
David
Forums Super Moderator
My GeForce 2 MX runs fine at default without a fan. Is it DDR or SDR RAM?
funnyperson1
Senior Member
i would see if you can run 3dmark a couple loops without artifacts....if you can do that you may be fine....but i wouldnt try it....running without the fan should be fine as long as you dont play any games....
Hardass
Hardass
Senior Member
I agree its not hot to the touch, as soon as radio shack opens i,ll see if they have one. Don,t know where else to get one.
David
You may want to try 'aiming' a case fan at the video card - get some airflow around it.
Hardass
Hardass
Senior Member
I have 1 in the front blows across and a side fan that blows just above
