- Apr 15, 2016
Hello all, this is my first post here and just wanted to ask a few questions. I just finished my water cooling loop and filled it up with some primo chill. Being a newb I thought this primochill coolant already had biocide in it. Well it doesn't and I've already filled up my res. I'm using a tube res from xspc. It's one of their combo ones. D5 pump on bottom and their glass res on top, all one unit. I also was under the impression that I could drop my kill coil in my res. However there is stuff blocking the fill port on top. I could try and wind the coil down inside but then i would never be able to get it out unless I disassembled the res which I would rather not do. My loop has only been running for a few days and only for maybe an hour or so at a time or 5 hours total. So this is where I'm at.
Basically my questions are:
Can I just put some drops of the biocide into the fill port on top of the res or did I need to pre mix it with my coolant before filling the loop?
How long do I have before algae will start growing? ( it is very dark in this room with the blinds closed but I do have uv leds in the case)
If I am able to get the kill coil in my res, why would I ever need to take it out?
Thanks in advance and sorry for the newb questions.
