Hi, is there anyway i can remove the heatsink of this card? I was told it was GLUED on the card! Is there a safe method to remove it w/o damaging the card? I want to water cool it.
One trick you could try is using a hair dryer or hot air gun ( ) to get the heatsink warm. Should soften the adhesive. Give the heatsink a twist like opening a bottle. Should come off. What I use to clean off the adhesive is WD-40 then rubbing alcohol.
i know for epoxy your supposed to freeze....if you do this don't fire your card up for a couple of hours (make sure all moisture has evaped!). Try freezing it...then twist it off like a bottle cap, if that doesn't work heat it up!
Has anyone done this before with this particular card?(Visiontek Geforce ti4200 128mb) If so I will give it a shot. I called visiontek and they said the heatsink was GLUED on the card and could not be taken off.
