- Dec 13, 2005
Is there any way I can check to see if VLC is using hardware acceleration or set it up so it does? Or is it file type dependent? Its just that when watching higher res movies windows task manager says VLC is using a high percentage of cpu usage, and sometimes the video becomes jittery or jumpy, and is running at around 15fps (I doubt a 8800GT would have problems with a 1080p movie, it can run crysis at that after all) Thanks
