Puer Aeternus said:
I have thermal paste on it right now..along w/ the black pad...later on I will scrape it off and re-apply the thermal grease. What does "Lap it" mean?
like Yodums said, you dont want both on there...Use a credit card or something of the sort, scrape off the thermal pad, and use Rubbing alchohol to clean it up real good, then apply some AS3..or AS2..depending on what you have...
oh yea..have you modded the Volcano7 yet?
its easy and the fan will run at full speed all the time after modding...just remove the thermistor,and twist(soldering is better) the wires together..cover with heatshrink or elec tape and your good to go....
oh yea..the Tt Volcano7+ is out now...(solid copper HS)
[EDIT: Lapping refers to a process of using a FLAT surface and increasing grits of wet/dry sand paper to remove the surface irregularities on the HS..there by increasing the amount of surface area contacted (HS& the DIE on the CPU)..wich allows better heat transfer, thus better cooling...there are a few threads here on LAPPING]
