By now, I think everyone knows that the volcano 9 heatsink is the same as the volcano 7's. The only difference is the outrageously powerful 76cfm SmartFan II that accompanies it. It is the SmartFan II alone that provides the main cooling power of the V9. However, if you've studied the aerodynamics of the V9 in action, you will see that the Smartfan II, at max rpm, blows out a ton of air, but not all the air can escape because the V9 only has 2 exit points on the sink itself and the shroud severly reduces the area of those exits. This causes a backlog of air and reduces the airflow from the 76cfm to something less (not sure how much, but a considerable amount).
With this in mind, some of you may be wondering whether you can mod the V9 somehow to improve airflow? Well, wonder no more. These good folks have taken the liberty to experiment for you!. Best thing is, this particular mod will NOT void your warranty
If anyone does decide to take up the mod, please inform us of the improvement (if any) in temps.
Regards,
Lazerin
Regards,
Lazerin
