Voltage Mod
Shep
Senior Member
Marshall, MO
I have a kt7-raid and a green 850 tbird it will do 1Gig easy but I want more when I set my multiplier to 10.5 x 100 I get registry errors my temps are 43c processor and 19c system. Would the voltage mod help? I also saw somebody had a link to the mod for more than 2.4 volts I would like to do this all at once. Thanks
Ok, first off, 2.4V is crazy, even with watercooling. I don't expect my chip to last too long at 2.2V, but I don't care cos I'll be upgrading in a few months time. Going from 1.85 to 2.1 or 2.2 will definitely get you to 1050, probably 1100, but I'd try to keep temps in low 40's at worst with those high voltages (41C max here), and that will be hard with a start temp of 43C (mine was 38C max at 1.94V, that's watercooled). By all means do it, but you might want to think about cooling more powerful than air cooling.
Ok, I don't plan to run my chip at 2.4v with air or ever for that matter I just saw a post here that said it was possiable by doing 2 different but related mods. I am planning on upgrading to water later I just want to get the most out of my chip and only do the voltage mod once.
