Voltage on Matsonic 7117C
raro
Hi, I've got a problem!
how can I change the vcore of the celeron II cpu?
The motherboard is jumperless and the bios do not have the voltage selection!!
There is a hardware solution like for the slot1?
There is a bios tweack?
Thanks a lot, Roberto Gatti, Italy.
Celeron II 667@833 very stable!
There are a couple of guides on the internet that allow you to carry out a small mod to change the voltage. Goto Yahoo.com and type in "vidpin" in the searchbox - That should find you the very best guide there is
Great! I've found it.
I'll try to put my vcore up to 1.9 V.
Then I'll let you know.
Thanks again, Roberto Gatti, Italy
