- Nov 28, 2005
Hi..
I have this problem with my Infinity mobo.. CPU and DDR voltages do not run at the specified bios value but at lower ones..
For example... if in the bios I set CPU voltage to 1.55 and reboot.. my current CPU voltage ( saw in the bios after reboot ) is about 1.50.. if I set it to default (1.50) It will be 1.37 .. and so on..
Same thing for the DDR voltages.. now it's setted at 2.8.. but current ddr voltage says it's 2.64 .. so If I want my ram to work at the default voltage of 2.6 I have to set it at 2.8
Is this normal or should I worry?
