volume control static noise
nakatalee
Mars
Hello everyone,
I have a quick question, my promedia v2 4.1 has a problem with the volume control knob. Everytime when i adjust the volume, i could hear a static noise which is quiet annoying. Does anybody has an advice on how to make it dissappear?
Thank you for any comment.
A while back when I was shopping for pc speakers I noticed the same problem on the demo model in best buy.I figured most of them would develop the same problem,thats why I never bought them.
To fix that I used to get a can of tv tuner cleaner spray with stereo volume controls and tv sets,It might work for you too if you can get the nozzle in the crack.
thanks, i will try that and i just found out that i can buy the control panel for $50, but it does not make sense since i got the unit for $25.
