Vote: Asus Rampage II Gene vs Asrock Supercomputer
FuriousGeorge
If you had to pick, would you rather have a:
-Asus Rampage II Gene
... or ...
-Asrock Supercomputer
The only major difference I see is that the latter does 4 way SLI / X-Fire, and the former only 2x.
Also, the former is mATX and the latter ATX.
Overclock-ability is a concern, but so are features... besides 4-way SLI... I can't ever see myself having 4 GPUs and a 1200W PSU with all them cables.
Please share your thoughts. Picking a side is great, and giving a reason is greatest ;)
Thanks in advance!
Nebulous
Señor Senior, Senior
The Empire State
My vote would have to be the Asus Rampage II Gene no doubt. :D
Asrock is not known for High Overclocking potential. I will admit the Asrock is a stable platform that you just set and forget. The Asus has the ability to oc like a bat out of hell which will give you much enjoyment when you're maxing out performance from your hardware.
F
FuriousGeorge
Thanks guys.
The 4 PCIe ports and the non-mATX form factor had me eyeing the ASRock, but my gut said 'Asus'.
Does anyone advocate for the ASRock?
nzaneb
Senior Member
Asrock....
Ok just kidding. While the Asrock offers quadfire support (you already stated that you won't use it.) For that reason only, why spend more for something you'll never use.
The Asus should do everything you need it too, for less money. Get the GENE.
Spyd3r
BC, Canada
Asus Gene. That was the board I was going to go with before picking up my UD7. It has most of everything I was looking for plus it apparently overclocks well.
