What made me go with EB's. Higher FSB. Plain and simple. Higher the FSB, the higher the bandwidth, the more 0's and 1's I can push through that chip. Higher FSB amounts to a higher memory bandwidth. Same thing.
If your going to watercool one CPU, do it to both. And seeing you have a motorcross background you might think this is a good idea.
I have an 85 250R 3-wheeler. Well, while trying to pass a buddy on his motorcycle he roosted me. One of the rocks put a hole in my left radiator. The right one was still good. I replaced both sides anyways. I still have the right one sitting here. I also have another VP-6 sitting here. I want to get a server case. I'm going to use that radiator from the 250,some 12V 120mm fans, and also use a big honkin holding tank. The radiator and the tank will take up the other half of the server case. I'm thinking that 250R radiator will work great. the lines are big, way bigger than the 1/2 tubing I plan on routing the coolant with. It will take sometime for water to circulate through that big radiator and I'm thinking should take it right back down close to room temp before it goes into the sump, cooling the submerged pump.
And if your going to watercool and pelt one chip, do them both. But still, I would see if you can offload both of those chips and get a matched pair, or at least two from the same lot.
