Should be the same as doing a vpn over any other medium. Windows makes it pretty simple to set up, on the client side you just create a vpn connection as you would a dialup connection, and on the win2k server they've got a wizard in the routing and remote access snapin.
Thanks, I know the vpn part of windows, what I nneded to know was how to get it over a cox cable lineand found out cox will only do it with business accounts.
