8800GT 512
Antec Solo case
120 S-Flex rear
120 S-Flex front (either in front of or behind HDDs)
Corsair HX520W ps
Asus P5K-E/WiFi-AP mobo
Crucial Ballistix 2x 1GB 6400s
E6750 C2D
TR U120E w/ S-Flex
TR HR-03 GT w/ unknown 92 or if 120(S-Flex)
3.5" Vantec fan ctrlr
(2) 36.7 Raptor HDDs SATA suspended
7200.7 Barracuda HDD non-SATA suspended
X-Fi
USR modem
LG DVD non-SATA
floppy
The front 120 S-Flex fan may be right in front near the case side slits, or if the HDDs will be cooled enough I'll put the fan between the HDDs and the cards and build a shroud to the lower HDD cage to suck and then direct the air flow upwards to the 2 TR coolers - the air to cool the HDDs would then be sucked in, not blown over them.
I'm just thinking a blower for the vid card area may just be the ticket to success. I am currently NOT planning on it, but I want to ask some of you here to see if any "blower" would really help the eqaution. I do not want it, but....I know the hw I've got here will certainly be getting a little hot, especially with overclocking. It would seem this type of cooler (a "blower") could be specifically beneficial if thrown into the build mix.
There are two approaches to this (actually I am not entertaining the 3rd way: cutting my side panel):
1)using the holes on the rear of the case beside the pci slots to bolt to -Horizontal
2)using the pci slot(s) - Vertical
There are many companies making products for either of these two solutions. Lian-Li for instance make 2 different rear hole side blower options. May include side panel (I won't do this). Artic Cooling I believe, as well as maybe antec have the pci type. Below are just non-specific examples. I need specifics if possible.
http://www.ncix.com/products/index.php?sku=14433&vpn=CYCLONE BLOWER&manufacture=ANTEC
http://www.antec.com/us/productDetails.php?ProdID=77194#
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3127373&CatId=804
http://img.alibaba.com/photo/50086377/DC_Blower_Fan.jpg
http://www.lian-li.com/product/product06.php?pr_index=52&cl_index=2&sc_index=10&ss_index=16&type=a
I will want a decent overclock with the listed components. I've got a pretty good jump on sewing this up. Couldn't be a "best ever" though- the price ain't going there, Starting with the Solo case, and these serious cooling products, I want to keep this build as QUIET as possible. Do you think that I should throw one of these "blowers" into the mix too? I would do that for : QUIET & fast & cool; ocability/piece of mind factor, package. But not just for the heck of it, and not if it'll add more noise and little cooling. Its a package deal. Its just about turning it up, keeping it cool, and making it QUIETER.
Antec Solo case
120 S-Flex rear
Corsair HX520W ps
E6750 C2D
TR U120E w/ S-Flex
X-Fi
USR modem
LG DVD non-SATA
floppy
