w00r i got UT2003
Chris
England, UK
I'm so happy i just thought id post this, I got UT2003 in the post this morning w0000000r. So what do i need, i need to update to the latest version i assume, are there any map packs or anything else needs to be installed etc?
NASsoccer
On a string I was held Senior
i live
yes you need to update at least to 2199 and you can get 2225 if you want, i havent gotten the newest patch yet because it isnt required and it was giving some servers problems. 2199 is at least required.
Chris
Chris
England, UK
cheers guys ill downlaod the stuff and update, ill be sure to see you all in the arena some time!:attn:
Pinky
Narf City, USA
Kendan said:
Then add [OC* to your buddy list so you can see who is playing:D Sometimes I play without a tag in which case you can find me by the name Trance. Hope to frag you soon;)
Thanks for the tip, I was spying/harassing Rottyz earlier :D
