why push bclk into high ra ge and possibly hinder stability when same clocks can be achieved with low bclk?
Ram has its own multiplier, uncore has also it's own multiplier. Both can be cranked as high as you'd like(with in increments) even while at default 133bclk. Only thing that rises is the qpi link speed, it has its own set of multiplier as well, but those dont have much room backward, so they keep rising even on lowest multi.
perhaps best choice would have been a x5660 if you use 20x multi and just crank from there. You would get the same result if your ultimate choice is to overclock via bclk. It would be cheaper too.
Yes, but you're limited to what the strap gives you. By raising the bclk you can work in between the straps for even more tweaking and thus a better overclock via nicer ram speed and higher uncore frequency.Ram has its own multiplier, uncore has also it's own multiplier. Both can be cranked as high as you'd like(with in increments) even while at default 133bclk. Only thing that rises is the qpi link speed, it has its own set of multiplier as well, but those dont have much room backward, so they keep rising even on lowest multi.
Yeah. You're way over extended.Well, temps were getting up there, but cpu can slowly ramp up into the 90s no prob when running bench for a longer period of time at lower overclock/vcore.
I have been in the 4200 range before.Dam, 4ghz uncore, nice.. I chicken out around 38-3900
I don't venture much over 200 bclk, she gets a bit cranky.
Sweet board man, That's the one I was going to buy.. shes a beaut.
But a W3680 on Aliexpress is like 65 beans.. and if I can get my mem clocks back, with the goodness the Xeon has to offer, well..
You know how they say these X58 boards are expensive? There's a copious amount of X58 boards in my area right now on Craigslist for sale for very cheap. I'm seeing an Asus P6T board right now with an aftermarket heatsink, 6 gigs of RAM, and an i7 920 going on sale for $70. Also seeing a W3680 going on sale for $80... which can probably be haggled down.
I haven't tried buying anything from Ali Express. I bought something from China on Ebay a few times... and all times it literally took a year to get here. It took so long I actually forgot I ordered it and was surprised to find it in my mailbox - so it's since scared me off from buying anything from China.
Test was run one time, hence not ultra scientific, but as you can see, its wicked close, so I can't say that running higher bclk gives any advantage. Having unlocked cpu does give you an edge in benchmarking because you can fine tune it more accurately like mentioned by Mr.Scott.
So, you have this W3690 CPU the OP has?
The difference between the tests is one tests RAM more than the CPU... during the RAM tests, the CPU isn't stressed as hard as during the CPU tests.
Yeah i have the same CPU.. trying to find a good stable OC @ around 4.1Ghz
