- Apr 28, 2011
Ok, so was recently thinking of a great way to cool my new computer, now that summer will soon be upon me. And after tidying up, i realised i had an Air con, from the previous summer that i didnt like to use to cool my unit, because of the large living area. So i thought, wouldnt it be great to be able to attach this Aircon to my PC. Which is where my Idea comes in.
General idea, is to send the cooled air directly into my case, there by cooling all the components. Without Causing a build up of condensation. So...Outline
My case is an RC Elite 430 housing 6 fan placements, one of which is on the side, directly above my Mobo and most major Components. (CPU, GPUm Ram)
So with this in mind, i set out to Construct a suitable/Experimental Cooling device. So basically, we start with the Air con, its free standing, so i can place it anywhere, and it comes with a drip tray for expressed water. Now because of the somewhat large vent, measuring 22cm's i couldnt just run a pipe directly from it to the PC. So i decided to use a Sturdy and resistant Plastic bag, made out of the same material as Builders plastic. about 8mm's thick with a life expectancy of 4 years. So, It would be shaped like a cone. This would extend to a 120mm opening at the opposite end, where it would attach to a PVC pipe. The plastic would be attached with Acrylic sealent at both ends. (Suggestions needed here for materials)
Then from that pipe, it would be extended to the 120mm Fan placement on the side of the case, secured by screws, and a bracket of some sort. Then just start pumping away
The Air Con is capable of sustaining a 22 Degree temp indoors when outdoors its about 35. it has a minimum setting of 16Degrees.
It wouldnt be a 24/7 setup, but would be used when doing Intensive operating of the computer. CAD/Gaming etc.
So basically i'm looking for opinions. some people may say its expensive. but considering i just have the Air con sitting there, i may aswell use it. And some may say its expensive to run it, but if its on for 3-5 hours a day, its only going to cost me 2.80$ a day. max.
But anyways, please feel free to comment.
