- Jun 11, 2002
- Chicago
Currently, I have an old Pentium HS enclosed in acrylic that I am using as a waterblock. Obviously, the performance is lacking
However, it is better than the stock HSF that I was using.
Temps are in the 39-41 range running [email protected] (ambient is 19-23) per the mb sensor.
I want to make a more conventional type waterblock. I'd also like to keep the design fairly simple. Attached is a picture of my idea.
The channels are 1/8" wide x 9/32" deep. Inlet and outlet would be 1/2". Overall size is 2" x 3" x 3/8" thick. Haven't decided yet whether to solder a top on or use lexan (which would require some more holes to hold it on.
My dad has a machine shop and the capability to mill this for me. I've already run the design by him, but not planning on starting immediately (he's thinking X-mas present). So there is time to modify the design.
Other info:
1/2" ID Tubing = .196 in^2
Channels 1/8x9/32x6 = .211 in^2
So the flow should be OK through the block (hose barbs would be the smallest part anyway)
Material is copper (of course)
Any ideas appreciated!
Other info:
