Want to fold gromacs
To get some gromacs WU's with the TEXT console do this:
Make a shortcut to the FAH.exe file. Click properties on the shortcut, where is says target, you want to put this AFTER the quotes: -advmethods Make sure there is one space after the quotes. If you are SURE your machine is stable, you can also put in the -forceasm flag. An example of the whole target in the shortcut would be:
"C:/program files/FOLDING/Fahconsole.exe" -advmethods -forceasm
Gromacs also work in graphical client- that's the only way I was able to get them to work.
steve ( 8(l) FOLD AND HOMER WILL BUY A DUFF BEER FOR YOU
mrm1957 said:
Thanks nikhsub. So what I'll have to do is delete the graphical client and download the console version. Do I have to download EMIII also ?
The graphical client works the same way. Just create shortcut and enter the following into the target field.
"C:/program files/FOLDING/winFAH.exe" -advmethods -forceasm
Notice the position of the quotes and there is a space before the dashes in both flags.
It forces SSE if your CPU is unstable while overcocking it. Normally, without it F@H would disable SSE if it locks up, etc... Make sure your system is stable before using forceasm.. Hell, if it is stable, you shouldn't even need to put it. ;)
