- Thread Starter
- #41
hi guys im back after a break...................
yes thats right the LLC is on Ultra High
my PC is on High Performance , not Balanced...........i think that answers AJ's question
im going to try and drop the LLC down a bit and keep my current Vcore of 1.375 and run Prime Blend again
ill be back later guys
The two screen shots are with the Cpu LLC at the next step up over high correct?
Temps look good though jumping the LLC and Voltage combined lead to a .04 max voltage increase. Which is a pretty hefty jump, I would take the time too see if you can lower the voltage a bit.
Why is core 2 only showing 56% after 5 Hrs?? Temps are just fine though still a step down from 1.375v!
I wonder if he has set in Windows to HIGH POWER!! Never asked him since he is new to OC.
AJ.
