Want to start my first mod... need advice
marc.L
Western Australia
I got my drill bit and apparently it is meant to cut through metal sideways like a jig-saw. (i.e drill a hole, then push across to cut out shapes)
My problem is the case vibrates too much so when i was practising i had to just drill many small holes to form a shape then cut the metal off with plyers (do u follow me?).
Is this a safe way to do mod's (on a budget, as i dont have a jig-saw or dremel or anything)
My idea is to install 2 case fans on either side of my case because idle temp sits around 44 deg celcius, but when i take off the sides it falls to around low 30's (i assume not enough cool air filtering through) with room temp around low 20's
Arkaine23
Captain Random Senior Evil
fan placement
Put the fan directly above the cpu, so it gets the benefit of that cooler air. Also, makes it easier if you want to make a duct for that fan.
Not sure if you'll have enough space between the motherboard and side panel to mount a fan on the other side, unless it sits outside the case. A blowhole in the top of your case might be better, but you'll have to be careful not to get metal chips/detritus on your motherboard or cards if you cut a hole in the top.
Make sure to adjust the amount of air exhausted from your case to try to match the amount of air coming in.
stool
Senior Member
Albany, NY
One bit of advice. Place a piece of thin plywood against the side of the case before cutting. This added rigidity will greatly reduce the vibrations. That sounds like a very impractical drill bit, or at least, very hard to work with.
FeralCom
I haven’t had any luck with those types of bits. I bought one for my Dremel and it didn’t do well at all. The package showed it cutting holes for faucets in a stainless steel sink. Maybe I should have tried it on a sink…or bought a stainless steel case.
Wicked Klown
Hard *** Southern Boy Senior
Sheboygan, Wisconsin
I know what you mean I tried the same. I also used one for a rotozip it worked a little better.
