- Sep 27, 2003
Warning About Soldering, Especially Tiny Components
Alright, I have known this for a long time, but I guess I shouldn't have been so stupid to not take my precautions. I used to do a lot of soldering at my old job, and have had the solder points come off, but I usually figured a way around by following the trace and finding another point to solder to.
The problem with computer components is that it's so crammed that it is hard to find a new soldering point, and even if you do, you don't know if it's going to go in parallel with another component and cause even more damage.
Here is what happened to me:
I killed my 9500np trying the hardmod. When I was getting ready to take the stock heatsink off, one of the caps from the back of the card must have "fallen off", literally. You can tell it fell off b/c the solder point looked dried out, and not forced off.
Sidenote: I've seen this happen plenty, as I'm sure most of you others have as well. It's not always the users fault. Since these boards have to go through ovens for mass production, they have to have solder paste pasted onto the entire PCB before the components are put on. Sometimes the paste may be off by a micrometer, and sometimes it's not enough.
Alright, so I used my $8 soldering iron to try to fix the cap back on last week, and soldered it back on. I never tested it after, like an idiot. ALWAYS TEST ANY NEW WORK THAT YOU HAVE DONE TO A PIECE OF HARDWARE TO RULE IT OUT WHEN YOU LOOK AT THE BIG PICTURE!!! This was probably my big mistake... read on...
I then removed the stock heatsink and the shim, and tried the hardmod to the card with the $8 iron, and the F-ing thing was too thick of an iron to solder the tiny points. It just kept melting the entire are of solder where the 3 solder points were... basically, I wanted to solder a resistor from points 1-2, to points 2-3, but points 1, 2, and 3 kept heating up. The resistor that was where the hardmod point was (position 1-2) ended up sticking to the iron and coming off. I then left everything and said "I'll wait for my Hakko936 to arrive." (The Hakko 936 -12 ESD is a very nice soldering station. Google it if you don't know what I'm speaking about)
I took the little resistor that fell off and placed it by the card (it's REALLLLLLLLLY small just to let you know, especially when you see it off of the GPU). I got the Hakko set up and warmed up, and then couldn't find the resistor that came off the hardmod points. It may have stuck to my hand and then flew off, who knows. I didn't think I needed it anyway, as I believe it was just a jumper. I did the hardmod by soldering points 2-3, put the heatsink back on, hooked it up and artifact galore!
I figured it was the nasty soldering job with the $8 iron on the cap that had fallen off, so I desoldered the cap off, and tried the card without the cap... same artifacts. I then undid my hardmod, and soldered back the initial 9500np soldering points... instead now it wasn't a resistor in that spot since it was gone, and so it was just a solder jumper on points 1-2. Card still had same artifacts.
I then tried soldering the cap back on to the back of the card, and it now just looks even nastier... It became a really nasty soldering job because I believe that the soldering point came off... tried the card again, and still artifacting the same way.
I think what happened is that the solder contact on the PCB itself must have fallen off... this used to happen a lot at my old job when we soldered parts onto the audio interfaces. sometimes the metal piece that is connected to the traces comes out... that's pretty much your solder point. When you create too much heat, the piece of metal heats up and pops off. It loves to stick to the iron, so a cheapo iron really is your worst enemy when you're soldering FINE POINTS. When this happens, you're usually screwed cuz you then have to hope that you can solder the electronic component to the actual TRACES, which is TOUGH to do, especially with a cheapo iron. In my case I had a Hakko936, and it took so long to get the cap to stick back on, but as you can see... the card is still artifacting, so now who knows the cause...
I can guarantee that the $8 iron was the cause. Either it heated up the GPU PCB (green area around the actual GPU die) too much, or it heated up the PCB on the back of the card where the cap was...
Now I don't know if the problem is by the hardmod, or if it's the cap that fell off... this is the situation that I created for myself by not taking my own precautions.
I didn't use flux at all with the $8 iron cuz I didn't have any, but I did use plenty of flux when working with the Hakko.
Precautions:
I have got to say, IMO, #4 is the worst thing that can happen, next to a physically broken component. When the metal piece comes out, you'll know what I'm talking about. Nothing angers me more because that is something that is only caused by being sloppy.
Don't be afraid to PM, EMAIL, or AIM me with questions, or request additions.
I may neaten up this post as time goes on. I made this post to keep others from destroying their hardware.
Special Thanks to:
RoadWarrior
Precautions:
- USE FLUX AT ALL TIMES IF YOU HAVE IT, IN ORDER TO ENSURE A CLEAN JOB! DO NOT USE TOO MUCH, AS WARRIOR STATED IN POST #4.
- TRY NOT TO USE A REALLY CHEAP IRON ON TIGHT SPOTS, AS A CHEAP IRON IS USUALLY TOO THICK.
- TEST OUT COMPONENTS FOR EVERY CHANGE YOU MAKE WHEN POSSIBLE. IF IT TAKES YOU 5 MIN TO TEST IT, IT'S BETTER TO BE SAFE THAN SORRY.
- DO NOT HOLD YOUR SOLDERING IRON ON THE SAME SPOT FOR A LONG PERIOD OF TIME BECAUSE IT CAN AND WILL RUIN SOMETHING. THIS CAN CAUSE DAMAGE TO THE PCB, OTHER SOLDER POINTS, AND WORST CASE IS THAT THE METAL PIECE INSIDE THE SOLDER POINT MAY STICK TO YOUR IRON AND COME OFF!!
- IF YOU DO USE A CHEAP IRON, YOU CAN ALWAYS FILE IT DOWN TO A FINER POINT, OR BUY SEPARATE TIPS FOR IT
Special Thanks to:
RoadWarrior
