Hello!
I have my Athlon Classic watercooled. Now i want to cool the watertank with 2 x 79 Watt Peltier. (the cold side on the coppertank and on the hot side a 160 x 80 mm cooper heatsink with two 80 mm Papst-Fans.
Now to my proplem: I want to buy (how? ;-)) a temperature controll for the peltiers.
The peltiers should get more voltage if the water is hot an less if the water is cold. But i dont want to turn the peltiers off! Only more or less voltage, because Peltiers die if you turn them off on off on ... ;o)
The peltiers are directly connected to my powersupply. (550 Watt)
Each peltier need 8 Ampere at the maximum.
Any Idea? A controll for fans is definitly too waek.
Sorry for my bad spelling ... i am a Austrian Guy.
c ya
PsyChoDaD
c ya
PsyChoDaD
