water block for 9800pro
DrSpanky
UK
dose the
DangerDen GF4/Radeon Block
or the
Koolance liquid cooler: Chipset / GPU
fit a 9800 pro?
it says they work for the 9700 but i dont know if it will fit on a 9800pro
and also what is the size of the gpu chip on the 9800 pro is it around 5cm x 5cm? cause i thought about useing a pelter on the core
any way give us feed back
what is the heat out put of the gpu?
and what power pelter would i need ?
Kunaak
Juneau Alaska
videocard waterblocks need to be around 40x40, so a 50x50 peltier would be alittle too big unless you made your own waterblock.
as for the dangerden blocks, yep they work. I one on mine.
as for wattage output, I have no idea.
