Water blocks
Hal 2001
I am abount to build my frist water cooling rig soon and am looking for some help.
At the moment I use a 72 watt pelter on a vos32 heat sink on a p3 600E @ 900. What I am looking for is the best slot one water block that will take one or two pelters at around 118 watt
Can any one help...
TIA
I'm using the Dangerden.com water block on my k7, i love it, they make one to fit your processer, you might want to check them out.
I would look and read some review on some block before you go buy one. I myself have the maze 2-1 does nice for me with a 156watt pelter on it.. I just order the Z4 block and will do a test on it and compare them. I will Post the results l8ter this week so look back for it... Also I talked to chip over at overclock-watercool and they are comming out with a new block that should be better then anything out on the market ... Here is what is looks like he sent me a few pics... not bad for prototype....
Went this thing comes out i will buy it and do another test with all 2 blocks well... just remember that when cooling with water electricy is not good :eek: LOL... Blackbox Aka Wolfsid
alright people after a couple of hrs installing the new Z4 the Aqua Sink and the Motherboard Water block.. All Bought from overclockershideout.com. I also purchase the Universal Hold Down Device And let me tell U it doesn't work with the Z4 nice with the maze just remember not to tighten it too much or SNAP U break the side parts on the cpu Just like I did anyway I fixed the problem buy buying some Plexiglass and made my own hold down devise with the 4 bolts around the Cpu. I think its a lot better then the side clips.. now for the temps... Notice the difference I bought a prob for all the test and its sitting right next to the core.. the system Z4 cooler with 156watt pelter and a 72 watt on the motherboard...
amd 1.4 overclocker to 1500 just for start
512 PC2100
GeForce2 pro 64 Getting the GeForce 3 ti
10000rpm HD maxtor SUCKS its The 2nd one from them and I hear clicking noises coming from the HD again after 3/4 full..
Temps at idle are from of CPU next to core is 15.2c back of Cpu is 28.0c
motherboard temps idle 14.4C not Bad:D
load CPU core temp 16.9c and back of Cpu is 31.0c
load Motherboard temps 17.0c
Z4 Is better then maze2-1 in all ways...
cool better and transfer heat real nice... no big difference in temps... Well this is the test I will be doing another test with the Z4 and the overclock-watercool new Block as soon as it comes out... replies welcome.. .Blackbox AKA wolfsid
Hack the World :cool:
