Hi there, im studying Technology in the UK, at college, i am on my final year, which i need to build a working product wich can be anything, with in reason (i think my idea just is border line within reason
) I have decided to build a water cooling system, with a computer case refrigration system, hopefully, this will make vapochill look like a 80mm fan
Size and weight is no object, so heres my design, tell me what you think.
The CPU, GPU and chipset are cooled by water, like a normal setup, the water will run out of the water blocks into the radiators, the radiators are small car radiators, measuring about the size of a full computer tower case, but a bit thinner, the two radiators are linked in series with eachother.
From the radiator the cool water will run to the reservoir, which will be containd in a mini freezer to chill the water, the freezer should cope as the water is cooled before hand by the radiators. The radiators will have one very large fan on each, kinda like a home fan for those hot days.
After the reserveoir the water is pumped back around to the blocks again. The CPU will have two 170 watt pelts on it, and perhaps (undecided yet) the GPU will have a small pelt on it.
The bottom half of the Computer case will be sealed, like a fridge, all disk drives will be placed outside of the sealed unit.
A fridge compressor will pump cool air into the bottom of the seald case, and will warm air out from the top.
The diagram shows what i mean if know one has a clue what im on about
ps, sorry for the spelling mistakes and typos that i missed, im using word pad, and i cant spell or type for my life
[img="[URL]http://freespace.morat.net/geenie/kwel.jpg[/URL]"]
