i have the right amount of water, the pump is 290 gpa, the block is not hot at all when its at 52c, i think its the hoses pullin the block from the chip, ill have to check that out.... how tight these springs supposed to be all the way down??? would a shim help?? the shim i got was really cheap lookin so i dint use it,[/quote]
i tightened the springs and now i am at 45c idle... anymore ideas, maybe tighten the springs more? their compressed down to the bottom...
