The watersink!
This might sound dumb, but...
What if you used a good all coper heatsink, and somehow seal off the top (the fins) into a plexi block or something (some kind of closed container), and then run water through it?
It seems that direct die cooling is not too safe, and water cools much better than air does. This might be a little hard to do, but I think it's a good idea. You might say "just use a waterblock" but I hear turbulence is a good thing. This should give lots of it, and more surface area to use for cooling should be better, right?
Here, would look something like this. Good idea or not?
