B
bob
Guest
Here's a list of what I used to make my water-cooled pelt system:
- Hayden transmission cooler - 5" x 12 1/2" x 3/4" (basically, 2 120mm fans covers all the fins)
- Maxi-Jet 750 - mag-drive pump going about 180+ gph
- BE Cooling Cu block
- Frost72 peltier running at 13.8V
- 1.5"x1.5"x1/4" Cu cold plate
- Tripp Lite PR-7b - 13.8V, 5A continuous, 7A max
- 2 80mm Sunon fans attached to the cooler (blowing out), running in series off the Tripp Lite
- Artic Silver thermal paste
- distilled water/Redline Water-Wetter mix
- misc - surgical tubing, vitamin bottle resevoir, home-made clip
What's the above attached to:
- everything above sits inside an Inwin A500
- block is attached to Asus S370-DL sloket insulated with neoprene front to back, GE Kitchen & Bath
Silicone, and dielectric grease
- in the sloket is a Celeron II 600 SL4PB (cC0 stepping) running at 1.01GHz (112fsb) at 1.80V
- AX6BC R type mobo which according to MBM 5.04 uses the GL518SM-1 sensor chip
- the rest of the equipment doesn't apply to the problem, at least I don't think so
The problem:
According to MBM, the water-cooled pelt system is doing worse than the Gorb when I run at 1.01GHz. At full load I see an avg temp of about 35 degrees C with the Gorb. Whereas with the water-cooled pelt system, I see an avg temp of about 40 degrees C. In both cases, I had my case cover off. (Btw, I calibrated MBM based on what SiSoft Sandra Pro 2001 reads.)
Question:
WTF is going on? Aren't I supposed to get low temps, maybe even below zero with a water-cooled pelt?
Plea:
If anyone has an explanation and/or solution to my problem, I would greatly appreciate your info.
The problem:
Question:
Plea:
