water cooler setup with 172watt tec
whiskeyinajar
tell me if this is good:
dangerden maze 2-1
172 watt tec
500 watt switchable AT psu
I dont know if the psu is big enough.Help
That is just fine, thing is though, does that PSU put out about 15-20 amps of current or is it the 1.5A kind? You need more amps then a regular PSU will put out. That's the sole reason mine aint hooked up. I am running straight water and am very pleased with my temps.
to tell you the truth im a little confused on the amp watt thing. temm me if this is right. watts are the total powrs and amps are the movement of the electricity. I think im way off.
WATT is the electricity running through and AMP is like a river. The bigger, more, watter running through tho more powerful the current. Make sense? The WATT is the water in the river. The AMP is the driving force, the current, for which the water runs. I am never that good at explaining these types of things. Hope I did ok.
Its all clear to me now. thanks a lot I look at the amps and watts on psu from now on
