- Sep 14, 2007
- Florida, US
So i pulled the trigger on a 900D case, and a rampage IV black mobo, i should get it by next week, now i want to start getting a list together on what i need
Basically i want to water cool my system listed bellow, i WILL be adding 2 more GPU by the beginning of next year so the setup must support 4 290x and one 3930k I want to use acrylic tubing since the soft tubing isued on other wc builds used to bend and prevent flow, so i guess acrylic is the new standard now..
Mobo: Rampage IV black
CPU: 3930k
GPU: 2x 290x (will add 2 more later)
PSU: Corsair HX 1050 (Will need to add another one)
RAM: 32 GB Corsair Vengance 1866MHz
Hard Drive: 2x 240GB SSD Samsung (RAID 0)
CPU: 3930k
