- May 22, 2011
- USA
With fans, fittings and tubing, sure it can get close to $500 but not just tubing and fittings alone. I think I spend over $200 on fittings and still have extras which you always end up having if you know exactly which fittings you need etc. I went with the Helix120 cause I didn't have almost $300 to buy all new Noiseblockers eLoop B12 PWM fans.
If you want, buy the Maestrom reservoir and tuck them underneath it. You could buy that reservoir plus the dual pumps if you'd like. Just don't run them on full power cause they'll suck up that liquid fast. lol
