Tecumseh said:
IF you want a safety advantage put two pelts side by side
on a good coldplate.
well, safety isn't the main goal I am after but only an afterthought.
I guess basically you could call this settup a water cooled coldplate.
Here's a little sketch I drew up of the first water block (acting as coldplate). The center is solid copper which would transfer the heat up through the pelt which would be applied directly above it. The base would be a light thickness of maybe an eighth of an inch and the top as thin as possible, total thickness 3/4". The water channels around the center core would take care of the spreading heat as it transfered out from the contact point and notice it surounds the copper core. This would have the effect of drawing heat out of five sides of the center core of copper. Remember there would be a pelt and a second water block such as a mazeII on top with it's own water resevoir, possibly chilled with an evaporator coil. The first water system could be a standard in case type settup.
The center looks like a cat so it could be called the "Meow block"
Someone must have thought of this before.
So, tell me why it will or won't work.
