Water Cooling on a Budget...
Status
Not open for further replies.
Trios
Oregon
Is not practical, spend the little bit of extra money on better/quieter air cooling if you don't have enough money for a real watercooling setup.
sticky...?
sticky...?
Yes, The many ellipsis' (2) make this a highly worthy thread.
Please excuse my bitter sarcasm.
I give you 5/10 for Successful Trolling, but a 1/10 for lack of enthusiasm and effort trying to stir things up. Maybe next time you'll have better luck! :santa2:
Hmm so your air cooling can beat my
$35 Eheim 150
$6 Maze 4 and adapter to s775
$5 worth of tubing ETC
$5 bong radiator.
That comes out to $51 about as cheap as decent aircooling and a whole heck of alot colder, considering no aircooler could even remotely hold 40°c while running a p4 at 1.6v and 4.5ghz.
Cheap water cooling has been proven as a very viable option countless times, both here at Overclockers.com and at numerous other online forums.
Statements like the one that started this thread are nothing but an attempt to cause trouble.
It is not an attempt to get help with budget water cooling.
It is not an attempt to start a reasonable discussion.
It is nothing but trolling.
It is not appreciated.
AC condenser, used, $15
aquarium pump, $20
reservoir, 2L drink bottle, $1.25 you also get some cola :p
Drilled copper block, $5
barbs, $5
tubing $4 for 10 ft
Exactly what roger said.
Useless thread.
*turns the key*
Status
