FrozenExistence
- May 8, 2015
Hi
I've recently assembled a new pc with the following components:
CPU: 4790K
MB: ASUS MAXIMUS VII IMPACT LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard
Video Card: ASUS GeForce® GTX 970 DC Mini
PSU: Thermaltake SMART M Series SP-850M 850W ATX12V
RAM: G.SKILL Sniper Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200)
SDD: Mushkin Enhanced ECO2 MKNSSDEC240GB 2.5" 240GB SATA III MLC
and decided to replace the stock intel CPU cooler with Thermaltake Water 3.0 Pro
Initially, I tried to connect the pump to CPU poer on the mobo and the radiator coolers to the chassis fan on mobo, but the system would shut down in 2 minutes. So I switched the power sources - connected the pump to the mobo and set the cooler to max and connected radiator coolers to the CPU power on the mobo. Under heavy load it still turned off. The temp does not seem to be the problem because as I monitor it with "HWMonitor_x64" they are lower with watercooling than with the regular intel cooler. I also tried to connect the pump straight to the power supply, it still turns off. what might be causing the problem? am I missing something? the pum does seem to work, because when I connect it I can hear the water pumping. Please help! spend a lot of money on this build and already dissapointed(
CPU: 4790K
