As I know I have 2 ways to go with watercooling. I dont wont anything extreme only good cooling at low noise.
The first way a "open" system with a water tank.
The second way "closed" system without a water tank.
I am like the second way more becaues less space and cheeper. But will the preformance be much lower without a water tank. And I am planing on geting the maze 2 waterblock and a radiator with a 92 cm fan blowing 35 cfm is that good or does it take more to cool the water. I have a 1000Mhz T-bird @ 1400 witch temp sould I get with watercooling 20-30 c maybe???
Witch radiator do you like and as I sad I wont a quite system And can I soundproofing a watercooling system and is a 600l /h pump good or sould it be stronger.
That is alot of questions and I hope you know the answers because I dont : )
