- Aug 28, 2001
- Sacramento/Davis, CA
Hey guys, I was hoping that some people could help me design a water cooling system. I'll list my questions so it would be easier to answer (sorta like a test).
The case I plan on using is the YY-0221B mini-cube server (it looks spiffy). I'll be putting my Tyan K7 Thunder with 2 1.2 GHz procs into it, as well as 4 IDE HDs, 1 SCSI HD in a bay cooler, 5 SCSI HDs in an ICY Dock, 1 DVD, 1 CD-RW, 1 floppy, 1 zip, 1 vid card, 1 snd card, 1 modem, and 1 IDE RAID card.
Lots of stuff ain't it? You can image the amount of heat dumped. Okay on with the questions.
1) Since I have two procs (no pelts or oc'ing because I want 110% stability) should I use 2 water circuits, one for each proc?
2) Should I use BeCooling's AquaCoil radiator or Overclock-Watercool's Black Ice low pressure drop radiator?
3) What kind of water pump should I use (brand/model)?
4) I know I want a reservoir tank (because filling and bleeding is a pain), but should the pump be in the tank or outside the tank?
5) Should I try to use air ducting for the radiators? And if I should, is it alright if I pump in the air from the bottom of the case (assuming that it's on wheels)?
6) If I used the Black Ice radiators, would there be ANY adverse effects if I mounted them to the top of the case (because of space constraints)?
6a) assuming it's okay, should I mount it with the fins protruding into the case or protruding out?
7) Shoud I get 12V pumps that connect to the PSU or 110V pumps that use the AC?
7a) If I use the 110V pumps, is there a way to turn them on from a switch on the outside of the case (assuming there is a switch)?
8) What is the difference between Purple Ice (BeCooling) and Water wetter?
9) Should I use 1/2" OD tubing or 3/8" OD tubing?
10) What kind of tubing should I use (silicon...)?
11) Would it be worthwhile to have a copper HSF (like the SK6) attached to the water block (assuming it fits, or I get it custom from OCWC) as a redundancy measure?
I think that's all of the questions that I have for now. I just wanted to clear these questions up before I bought anything because water cooling can take a big bite outta my bank account :|
I appreciate any advice you guys can give!
