Water Cooling VooDoo4 4500 PCI...
DDR-PIII
Disabled
6p6
I'm gonna go this thing a try with my 4500 PCI and see if I can get the speed from the default 166 from what i'm using now 190 to 220Mhz... Will I have to cool the memory also ?
Thanks..
You might as well cool the memory with RAM sinks...couldnt hurt if you use Artic Alumina adhesive...
lol, is a voodoo 4 with water cooling.
how much would a block and ram sinks cost?
taht could be a new vid card right there. no offense at all :p
just my 0.004 pennies.
if your making it urself go for it, the challenge will be fun.
If you make it yourself it shouldn't cost more than 30 or 40 bucks.
I found an easyer way to cool....I just stuck the tower in my bed room window and waited for about 15 mins and OCed :) it was pretty windy out said prolly -35celcus with winchill
